The BFD session failed to set option on a communication channel which communicate with the outside world
When this happens packets can neither be sent out, nor received from the network. See if restarting the process solves this problem. Under normal circumstances this should not happen, however if it does, please contact Extreme Networks Technical support.
Error
Failed to set socket %option% error: %errormsg%
| Name | Type |
| option | String |
| errormsg | String |
